I have been having problems with my heating for a little while (downstairs rads not getting warm / all a bit noisy ect) but with the help of this forum, I managed to get it all working fairly OK.
Only problem I had left was that the control system was very naff so bought a new Danfoss heatshare pack (OK not the best, but as three port valve was Danfoss, thought it should be easiest to fit)
Changed the electrical side on Saturday and all fine, changed the 3 port valve Sunday, and all fine for about 8 hours. After that all the radiators have gone cold. Tried bleeding at the bleed valve next to the cylinder (on a 1 ½ foot vertical bit of pipe) loads of air.
Ran the pump for ~5 seconds I could feel this pipe get cold again. Stopped the pump and tried the bleed, and sure enough full of air again. Repeated this until I got bored.
As I see it, the pump must be sucking in air somewhere, but does anyone know how I would tell where. Will probably change the three port valve back for my old one tonight and try that – old one was stiff to turn – how stiff should it be? Don’t want to damage the actuator. (Never been able to have HW on without getting CH also in past so could live with sitting actuator on floor and turning valve manually)
Any help / advice would be gratefully appreciated.
J
J
