Hello alarm gurus,
I have never installed an alarm system before but I am looking forward to giving it a shot.
I have put quite a lot of thought into how we would like the system to work and I believe I have chosen a system that is capable of meeting these requirements but I would like to get the opinions of others that know more than I do and also to ask a couple of questions that I have not been able to find the answers to.
The main building will form one area, there will be 16 zones and 2 remote keypads. This is where the control panel will be located. I will need to install an extender board into the panel I believe to get this number of zones.
There is a second building on site that will be a second area, this will have 8 zones and 1 or 2 remote keypads. There will be an extender in this building.
There is a third building that will form area three, this will have only 4 zones and 1 remote keypad. Again this building will have an extender.
All keypads should by default arm/disarm and show the status of the area the keypad is located in but there should be the option to arm/disarm/get the status of the other areas too.
Everything should be hard wired, nothing should be wireless.
Looking at grade 2 or 3 units.
I have been looking at a Premier Elite 48 or a Premier Elite 88 to meet these requirements. I would be open to suggestions/other products/manufactures also.
Does the above seem reasonable/feasible?
Can each area have its own sounder or will all sounders go off regardless of area in the event of an alarm?
Two factor authentication, is there the facility to have a key-fob and a code that need to be entered to disarm the system?
Can an area be armed automagically if there is no movement from the PIRs in a given time?
Can a user only be given permission to disarm an area only into a part armed state? I am thinking of the cleaning team that only need to access certain areas, they will then full arm on their leaving.
Thank you for your time.
