Hi all
I've read the sticky and still can't work this out.
I'm fitting a new light in a bathroom. It's an upstairs flat so all rooms bar the hallway light is on the same level.
I thought I connected everything correctly, as the bathroom light works. The switch turns it on and off. Seems fine.
However
One bedroom and the living room lights do not work now.
The kitchen, landing and the other bedroom work fine however.
I assume this is a circuit and I've messed up somewhere stopping the other lights working.
Can you check my photos and see if there is anything obvious?
I wondered if it's the block which 3 red wires are into as it does seem a bit flimsy but I've screwed the screw all the way down and all 3 wires are in so I think there has to be contact.
Any help appreciated.
Dcarr.
However
Dcarr.
