new boiler
11 Jun 2005
Cambridgeshire
hi helpers, my potterton primaF 50F boiler is over 15 years old so now would like to change it and fancy a combi this time
what would be an equivelant boiler to exchange with, eg potterton or valliant
we have 11 rads in the house and will probably have the system power flushed out as some of the rads are only luke warm at the bottom after balancing/bleeding cheers P M
Wouldn't put a combi in my own house.
If you have a hot water tank keep it.
Or if you are having a combi you need to put in an electric shower
as a backup.
If you live alone in the house than a combi will cost more to install but will suit you fine!
Otherwise keep your tank!
They are not a fashion accessory!
there is two of us in 4 bed house and soon to be 3 adults and a child
we have a shower in en suite
so you think i should get a normal boiler and keep the tank wihich has an electric immersion heater as back up
I suppose it will keep the costs down swopping like for like ?
oh which boiler shall i go for cheers and thanks P M
some parts of cambridgeshire have quite poor mains water flowrate which would rule out a combi.
vaillant is a good idea
The setup you have now is perfect for the demands you will be placing on your hot water system. A combi would be an expensive mistake.
What is wrong with the Prima? If the boiler is working well, but rads are not performing, save your money on a boiler for now, but get your system flushed and inhibitor added. Also, make sure that you have thermostatic rad valves, hot water and room stats, so that your system runs efficiently.
If you have good mains and want mains pressure hot water could always go with system boiler and unvented cylinder?
Well said, this echoes my own thoughts exactly. If it ain't broke, don't try to fix it, a new boiler won't pay for itself if the existing one is reliable so save your money and do nothing apart from the powerflush. If you want better pressure on your hot water system, add a pump.
True flush out the system and see how you go as the system should be flushed before a new boiler goes in anyway
