I have a hole in the outside wall, underneath the kitchen window / corner where the boiler is. I presume this was drilled in error, because there is another one on the other side of the same wall where an overflow pipe exists.
overflow:
I measured the depth of the rogue hole and it goes in 33cm. I don't know if this is hitting brick, or if it's hitting the plastering, or the back of a kitchen cabinet.
1. Has this hole (which has been there since the house was built 2 1/2 years ago) caused any damage?
2. Could this hole cause damage in the future if left alone?
3. Do I need to just use sealant on the outside or should something be done to the inside such as the inside wall or the cavity?
overflow:
