new-build ceiling question
dg9
28 Dec 2010
Midlothian
hi
i've recently moved into a new property - and was wondering what the professional opinion on the following is:
someone has recently moved into the flat above mine and there seems to be more noise from above compared to the previous properties i've lived in (both new build and older).
Should the lampshade ever shake due to 'normal' movements in the property above?
(i say 'normal' as it does not seem they are doing anything particularly outwith the 'norm')
thanks in advance
Normal movement, No, bouncing up and down maybe!
does the ceiling void have soundproofing installed?
Thanks for that.
It was definitely just walking about the property and not prolonged movement/bouncing in one area.
No idea about the soundproofing, how could i tell?
thanks
does anyone have any other ideas with this at all?
thanks in advance
try seducing the ocupants girlfriend, therefore transfering all movement onto your floor :eek:
Are the occupants or their visitors in the flat above you outwith normal sizes or weights?
Do they seem particularly keen on any active sports or other high energy activities?
This is what I have gleaned for what it is worth. New builds should have good noise insulation between dwellings. Floors can either be constructed using tried-and-trusted 'robust detail' designs or have noise insulation measured. It may be that some penny-pinching has left your noise insulation below regulations.
  • Thanks
Reactions: dg9
