Hi.
Bloc and beam with poly expanded block...
We moved into a shared ownership house ,its only a year old...we noticed moisture under the sink unit in July 2010 by Sept 2010 it was rotting the unit by January mould had expanded a fair distance and high condensation found on water supply pipe..
Chartered surveyor said ground level is to high (builder said double dpc so not a problem) and we have noticed the screed in has bridge the edge insulation also draught coming from most skirting board areas....
The dpc under the internal skimmed wall has a slight gap under it enough to push a knife through....is this normal
