If it is condensation causing the damp walls then maybe it is trickling down the upvc and is being absorbed by the wall. Note earlier in the thread I said the ventilation should be addressed in order top eliminate it as an issue. Once you leave the windows ajar if there is no improvement then there will be something else causing the problem. But the lack of trickle vents issue does need addressing.
