New CH system and running Hep2o pipes
11 Dec 2010
London
Hi all I'm planning on a New CH system with Combi-Boiler will all new Rads also this house currently has a warm air system which is being replaced.
1. I would like to run the pipes in Hep2o barrier i believe. idea is to drill holes into joists and feed 22mm pipes I have a long landing so will be the main run.
2. i was thinking of channeling in a few pipes on the ground floor to conceal the pipes, is this a good idea? what can i put in the channel to prevent long term issues?
3. is it worth me buying a right angle drill to make holes? as will be making a few holes everywhere
look forward to your thoughts thanks
1. Yes 22mm is the best size to supply to radiators, than size down to either 15mm or 10mm just before the rads. Make sure when you drill the holes the pipes have enough room to expand and than you sleeve the pipes.
2. plastic pipe buried in the sub-floor needs to be run in conduit with one continuous length of pipe and no buried fittings.
