    Dismiss Notice
New cold flat roof ventilation advice
Discussion in 'Roofing and Guttering' started by Coyney, 29 Oct 2016.
  1. Coyney
    Coyney
    29 Oct 2016
    4
    Thanks Received:
    Country:
    Hi all,
    I'm new to the forum and purchased a 1950s detached house about 6 months ago.
    The existing flat roof of a two storey extension was sagging badly and had damp spots. A relative of mine is a roofer and replaced the 5m x 3m area with new joists, plywood and several different layers of torch on felt.
    Upon completion I decided to look at the different options of insulation and noticed that this was deemed cold roof construction without ventilation. I can generally put my hand to most tasks but have never been involved in flat roof construction.
    The 5inch joists are exposed to the underside and I haven't yet insulated it so I can still acces the underside.
    Is there a way I can ventilate it as I don't want to rip the roof back up? Can vents be added to the fascia boards? I was going to buy 75mm celotex to ensure 50mm clearance but am now worried about potential condensation, after reading about its construction online.
    Thanks in advance,
  2. Sponsored Links
  3. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    19,557
    Thanks Received:
    2,186
    Devon
    Country:
    WTF? You had a 'roofer' do this for you and you're only thinking about ventilation and insulation after its been built?
    Anyway, got some photos, which way do the joists run, how is the fascia suspended?
  4. Coyney
    Coyney
    29 Oct 2016
    4
    Thanks Received:
    Country:
    Thanks for the response. I know, it's frustrating, but I've never had a flat roof and didn't realise until I researched insulation.
    The joist run from the main roof outwards. The first photo shows them running into the wall furthest away from the house.
    The following photo shows the joists running up to a wooden fascia board.
    This is the end where the joists butt up to the blocks of the main house. Above these there is some timber that I may be able to drill through to get to the main roof space.
    This is the view from the main house showing the fascia board.
    Any advice on venting this and also on the insulation will be much appreciated.
    Thanks.
  5. dom_k
    dom_k
    7 Aug 2016
    35
    Thanks Received:
    10
    Country:
    I'd put 75mm between and 50mm under joists. Not quite enough to meet current building regs though. Re the vents an over fascia vent would have been good. Do you have a soffit on the gutter edge? At the other end venting into roofspace may be your only option.
    I'm guessing the roof may have been shot due to decayed timber from lack of ventilation?
    • Thanks Thanks x 1
  6. Coyney
    Coyney
    29 Oct 2016
    4
    Thanks Received:
    Country:
    Thanks for the advice regarding the insulation. Would you also use 12mm foil backed plasterboard over it?
    Unfortunately there is no soffit as the fascia is almost flush with the brickwork. Can I fit vents directly on the fascia? Would you fit them between every joist or is every other one enough? What vents do you recommend? I'll drill holes and vent into the roof space as suggested.
    The old roof was vented with 2 roof vents. In the centre there was about 5 layers of felt to try and patch up a leak. Over time I think the weight of a puddle caused it to sag but it continued to leak through on to the timbers.
    Thanks!
  7. Coyney
    Coyney
    29 Oct 2016
    4
    Thanks Received:
    Country:
    Please can someone advise on this? I'm hoping to somehow add some venting and insulation this weekend?
    Thanks.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
