- Joined
- 28 Nov 2019
- Messages
- 97
- Reaction score
- 0
- Country
Happy new decade all!
I'm having my bathroom redone and it's getting there. I have recently changed to a combi boiler (Greenstar 30i) and my water rate is 11 litres a minute.
I'm having a walk in shower and I wanted a concealed thermostat. The builder said that was fine but suggested an external unit because his previous clients had been burned because when their thermostatic mixers fail, they can't get the same model/dimensions and it is a big issue.
I investigated the major manufacturers (because I assume they would have higher success rates and keep same models in stock) and found that their prices were absolutely crazy. I settled on this external unit and decided that if it goes bust, I can always easily replace it:
https://www.amazon.co.uk/Hausbath-Shower-Thermostat-Wall-Mounted-Thermostatic/dp/B07MT5WRQ2
This is my shower head, which will be connected to the ceiling via concealed pipes because I still want the concealed look https://www.homebase.co.uk/d-lucci-sensor-square-shower-head_p386366
I have purchased the following elbows to come out of the thermostat to go into the wall pipes: https://www.screwfix.com/p/aqualisa-shower-hose-wall-outlet-chrome-67mm/5208G
Now my question is this, will the size of the concealed pipes cause a problem with the amount of pressure the shower head gives (I can see the output hole from the thermostat is quite small)? What is the optimum pipe size I should have?
Secondly, where can I buy a 15 or 20 cm shower hose to connect the thermostat to the elbow (I want the elbow as close to the thermostat as possible, and I don't want a permanent fixture in case I need to replace the thermostat in future.
Thank you all for any suggestions/advice.
Thanks again.
Thanks again.
