Guys/gals, a couple of months ago I posted a topic about my shower having a burnt out fuse and was rightly advised by the replys to pull the fuse which I did,since then I have run a temp feed from the taps to a shower head ,,,,,,,one of those cheap flexi hoses,anyway had to put up with that as my finances was stretched in other areas.I now have some finances too update.
I have the old wired fuse box with 3 fuses in and the 4th one pulled which was the shower unit which I wish to upgrade to the circuit breaker type but as I am not qualified will call a sparky in, the shower cable also appeared melted in the loft when I was up there so I will run a new cable ready for the spark to wire up,the shower was there when I moved in and it is a faily new triton jade but I could not find the kilowatt ,now my questions are what size cable will I need to run in ,it as about 3 m in boxed in area covering pipes/cables 2m under floorboards and 4m in loft space,will a 10mm be ample if its 9.5k or 8.5k and is there anything else I will require,also I am upgrading the old consumer unit is this a expensive job????? and I dont suppose I could help here
