new CU
13 Oct 2004
Hi sparks
I recently added a separate ring main to the downstairs of my house separating the ring upstairs from downstairs and also separating the kitchen with a new ring. I would like to get a sparky in now to add a new CU with MCB's instead of fuses. There is limited space in the CU cupboard where the current fuseboard is which is approx 260mm * 210mm.
I have included a picture of the unit. I would like to know what CU to buy. I have in total
* 1 upstairs ring
* 1 downstairs ring
* 1 upstairs lights
* 1 downstairs lights
* 1 kitchen ring
* 1 cooker cable 6mm
going to the CU but would like to extend this and put some electrics in the shed/garden so would need room to fit this in to! My questions are;
* what consumer unit do i need that will fit this space (is there options make more space?)
* what do I need to put a couple of security lights in the garden, socket in the garden and socket in the shed
* how much should a sparky charge to replace the CU only
many thanks in advance
chips
View media item 6111
Looks like you have an overhead or TT supply. Where is the main earthing cable to the installation?
What mA rating is your RCD?
If you have TT, ask your DNO to convert to PME.
You have more space than you think. Please measure the space occupied by the white CU and the grey RCD unit - these will be integral in the replacement CU. Is the measurement more like 370 x 210?
However, it would be handy to have an isolation switch fitted....can you make the cupboard bigger?? ;)
But you don't buy it - your electrician will do that, and he'll pay less for it than you will.
An electrician.
About the same as a weekend away in a hotel for you and a partner.
You should really get an electrician in sooner rather than later. He will be able to answer all of these questions and more.
He'll want to fit a dual or high integrity fuseboard and will know which one to get. But he won't simply come 'round and fit one for you without testing and approving your alterations.
Could be incomer board with RCBO's, as long as you have PME conversion.
Trouble is, looking at Wylex (as they are more compact than, let's say, Hager), the boards are all 230 high & 120 out from the wall.
The 10 way is 293 wide and the 14 way 344. If you wanted bigger, the 19 way is 440.
But whichever you choose, they will not fit your cupboard!
You could space off with 1" spacers or a bit of 2x1 and hang the board over the supply tails underneath to gain height.
Or if your chosen brand of board isn't too rigid, especially as TT rules out metalclad, mount some ply then fix to that.
Many thanks to all your replies. My friend from work who does all our electrical work is coming down with a new CU. He'll know what to make of it all!
Chips, The work you have already completed Plus the additional work you propose to have done are ALL controlled work & come under the Building Regulations......Google Part P for advice
Is your friend competent to design circuits?
Is he competent to design an installation compliant with BS 7671:2008?
Does he have, and know how to use, all the test equipment he'll need to test the installation before & after installing the CU?
Can he issue an EIC with any validity?
Is he registered to self-certify compliance with the Building Regulations, or are you going to apply for Building Regulations approval in advance? If the latter, have you confirmed what your council's position is on DIY electrical work, and what their charges are?
If it was better, surely there wouldn't be restrictions on when it should be used.
