So I used to have a free standing oven with hob on top. It was fed from the board on a 40 amp mcb in 6 mm cable via a oven outlet plate. I have now got a separate double oven and hob. Can I take two 6 mm cables from the oven outlet plate one to each piece of equipment? Leaving the 6 mm supply and 40 amp mcb as I believe 6 mm t and e takes 40 amps. And therefore the cable us protected
Also the hob comes pre wired in some rubber flex, this is not long enough so I'm assuming it will be ok to change this to 6 mm t and e?
Thanks for any help[/code]
