Just bought a john lewis own brand electric oven that has absolutely no info on wiring ! eventually I found a sticker saying it is 3.2 kw, I think this is over the limit for a 13 amp circuit.
I had a 6 mm cable with a 40 amp mcb fitted thinking I would need more power for an electric oven, I have this fitted to the oven outlet plate ready for connection, I am not sure if this cable too large for this oven so, should I just connect more 6mm cable from the oven outlet plate, and use the 40 amp mcb or reduce the mcb or use 2.5 mm and reduce the size of the mcb to ??16 amp??
I can't believe the total lack of information, nothing in any handbook, even the connection plate at the rear gives no more info but the cables leading off it into the cooker look like 2.5 mm or smaller.
