I'm planning to fit a 7.5KW induction hob which I would like to connect to a radial 6mm T&E cable through a 40 amp mcb at the consumer unit. Is this OK or should I reduce the mcb to 32 amp?
Also, the 5.7KW double oven I want to install has the possibility to be connected to a separate radial 6mm running through a 40 amp mcb. Is this OK, or should I also reduce the mcb to 32 amp?
And, is it OK to make the final run to the hob and oven in 4mm?
