New En Suite tiling
29 Nov 2008
In the process of doing a new en suite. The tiling is a major thing I don't want to bugger up. I was planning on doing this myself as I have done my kithchen floor and walls, but a Shower and Bathroom require a bit more know how I guess !!
I am now thinking about getting a pro in. What can I expect to pay for about 20sqM, of floor and walls. Mainly square room, with a Shower (not a cubicle, but not a wetroom either).
The walls are all flat (well, they look it to me !!) and the floor is freshly laid plywood.
I will be suppying my own tiles.
My biggest concern in tiling a job someone else had prepped would be weather or not it had been done correctly. Some may not be too bothered but it’s my reputation at stake so if I’m at all unhappy about what’s been done, I wouldn’t touch it with a barge pole! Far more care is needed in the selection of materials in a bath/shower room than a kitchen, both for the tile base & selection of the tiling materials themselves. You need to take account of many things especially tile weight if using large format tiles.
For the floor; what sort of plywood did you use (must be WBP, ordinary ply is no good)? Did you replace the floor or overboard? What thickness ply? What is the floor joist size/pitch/span? Did you seal the back & edges? How did you fix it down? If you’ve no cubicle do you have a tray? The floor will need tanking if it’s going to be continually exposed to water even if it’s not strictly speaking a wet room.
For the walls; plasterboard has a max weight limit & this reduces considerably if it’s plastered as do plastered walls so the size/weight of your tiles is an important factor & large format tiles must use powder cement addy not tub mix & plaster needs priming when cement addy is used. Plaster board should not be used in wet areas unless it’s tanked, use waterproof tile backer board which will also accept higher tile weights.
Finally, I would only ever use branded tiling materials I trust supplied by someone else, cheap DIY crap is definitely out.
As for cost, get several quotes but it could be anything between £25-£40 sq/m depending on many factors including your location. Be very careful how you select your tiler though, not all are what they say & some can’t even bloody tile! If you’ve already done your kitchen & not totally balled it up, I see no reason why you shouldn’t be able to make a decent job of it yourself as long as you do the research, follow some simple rules & take your time. :wink:
Hi Richard C,
Thanks for that lengthy and comprehensive reply. I fully understand what you mean about doing a job someone else had prepped. But 95% of the walls were already there !!!
Mostly plastered, with a mixture of new and old stuff (1930's probably) !!
The cubicle has a tray so the floor won't be exposed continually and is surrounded by 3 plasterboarded/plastered walls, which were there already ! How thick is the waterproof backer ? Should I rip out the original plasterboard and stick this stuff up ? Or can it go over the top of it ? :?
I did lay the ply, but it could easily come up again, it is just normal 9mm stuff ontop of the floorboards !! :oops: Screwed down every 150mm. What is WBP ? As for the joists ??? :oops:
LOL, I bet you guys laugh at us DIY'ers !! :lol:
It all looks so easy, till you listen to someone who knows what they are on about !!!
Richard, I will take all that onboard. The tiling, is the most important aspect, so I wanna get the prep right.
So in summary :
What thickness WBP? Do I need to go over the top of floor boards (and what is it !!), I aint pulling them up.
Do I ONLY need the tilebacker board in the shower cubicle ? and can it go over the top of plasterboarded walls ?
And I am only planning on supplying the tiles to a tiler, he would supply the other stuff (adhesive, etc). If I do decide to DIY, what products are recommended and where from ? Abbreviations are no good, I won't know what they are !!! :wink:
Thanks again mate.
It’s not rocket science, but as well as the skill involved in actually laying the tiles, you need to understand the various materials being used & their suitability/compatibility with each other. If only peeps took a little time to do some research before jumping in, it would save them an awful lot of heartache when things go disastrously wrong & expensively so in many cases.
WBP is “water boil proof”; basically means the adhesive used to laminate the plies is waterproof & the ply won’t fall apart when wet. Ordinary ply does not use waterproof adhesive & applying water based tile adhesive or using it in a location which has a high ambient moisture content can cause de-lamination & there go your tiles! Sealing the back & edges prevents moisture getting into the ply which can cause warping & curling; again there go your tiles.
Some will disagree with me but 9mm ply is not thick enough for over boarding really; the min thickness recommended by BS & tile adhesive manufacturers (for warranty purposes) is 15mm but it’s generally recognised that 12mm is sufficient in most cases. This can be a problem for the door threshold height & sometimes it’s better just to rip them up & replace with 18-25mm WBP. The thickness you use depends on the floor joist size/pitch/span & the aim is to end up with a floor that has no perceivable deflection under normal loading; if deflection exceeds the spec of the flexible tile adhesive/grout being used, the tiles will fail. Someone recently posted they used the “two fat bloke test” & a piece of string to gauge any deflection. It’s important the existing boards are well secured to the joists & the overboard is screwed through into the joists not just top the top of the original floor boards but check for pipes/cables.
If you have “proper” timber floor boards in good condition & a high door threshold is a problem for you, tile backer boards may be a better option for over boarding.
95% of the walls were already there !!! Mostly plastered, with a mixture of new and old stuff (1930's probably) !!
Tile adhesion will only ever be as good as strength/adhesion to what they are stuck to so it’s very important the plaster is sound & actually stuck to the wall!
For walls only use 12mm (12.5mm) boards.
Personally, I would replace with 12mm waterproof tile backer boards. You can use plasterboard in wet areas but it should be tanked or you risk failure & the cost difference will be negligible when you factor in the cost of tanking. But if you have a canceled shower valve, the back of the PB will still be vulnerable in the event of a leak & could collapse from within.
You can fix over the top providing you fix through into something of substance but this will take up more space; are the walls timber stud or has the PB been dot & dabbed onto the original walls?
I would still tank the portion of the floor that is liable to regularly get wet & if you have a power shower it certainly will.
Do I ONLY need the tilebacker board in the shower cubicle?
You can use Moisture Resistant plasterboard in dry areas but it will depend on the tile weight your hanging & with large format tiles you must use powder cement adhesive which, along with any Gypsum plaster, will require an SBR/acrylic primer to avoid the possibility of a reaction between the cement & gypsum. If you need to plaster MR plasterboard (when ½ tiling) it must be primed or the plaster won’t stick.
What size/type of tiles are you planning to use? This will dictate what you do with the walls. For example; new bare plasterboard will accept 32 kg/sqm but plaster skim & plaster in good condition will only take 20 kg/sqm & that includes up to 4 kg/sqm for the adhesive/grout. If you’re planning large format tiles, the weight may mean you need to go to 12mm tile backer boards (mechanically fixed) which can take 55 kg/sqm depending on which one you choose.
It’s important you use quality trade products, the cheap DIY stuff is mostly crap & one well know brand sold by all the DIY sheds has a diabolical reputation. I use BAL exclusively but other good brands are Webber, Granfix, Mapei (but not the stuff sold in BNQ). Either buy on-line or fend your nearest trade tile stockist. Topps are notoriously expensive for adhesive/grout products sold to unsuspecting DIYers but you can get a trade discount at many of their outlets if you try hard enough & look the part.
