New front door
1 Nov 2007
Hertfordshire
I'm planning to replace the rather flimsy front door of my house (1970s, probably pine framing, with large upper and lower glass panels) with a more modern timber one that will keep the cold out better. Probably timber panels, with only a small amount of glazing in the upper half.
Looking at the popular DIY stores sites, I see many doors which are described as "oak veneer". Are they really robust enough for outdoor use, or should I stick to "hardwoord door" or other such description? Even "hardwood door" could, I suppose, be a veneer, so what are the buzzwords I need to look for please?
Secondly, many of the pictures on the web sites show the doors without any letter box or other ironmongery. Is it standard procedure to have to cut the letterbox slot yourself, or if there's no slot does that mean the door would be weakened too much if one was to put one in?
get a hardwood door not veneer and yes you have to cut out your own letter box hole
If you have room beside the door, to the hinge side, put your letter box there. It is possible to manipulate rimlocks and doorkeys through a letter box using a simple home-made tool, and the further away the letterbox is from the lock, the better.
Sorry I didn't get back sooner, and thanks for the replies.
I'll definately go for hardwood, rather than veneer. My initial searches of the popular DIY stores brought up many hardwood-lookalike-veneer ones, but on Googling a bit further I've found plenty of hardwood ones at even cheaper prices than the veneers :D
No room for a letter box beside the door, so I'll go for the traditional letterbox cut into the door.
