New heating system - boiler choice
You may want to take the advice of morrismini with a few grains of salt, he is not a pro,
Oh I'm a full pro OK, that is obvious by what I write. You are another waste of space which clutters this forum.
Unvented cylinders? With most having a pressure reducing valve to 3 bar? Nah. They restrict flow. A thermal store, or large combi, using a plate heat exchanger, can take up to 9-10 bar and no pressure reducing valves to go wrong and reduce flow. If you have over 3 bar an unvented cylinder can reduce flow/pressure.
If you have 5-6 bar main and want to us that for a high pressure power shower? Don't get an unvented cylinder.
A combi, no reduce in flow, that statement alone proves you have never fitted one.
Mr Bob, if a combi say it delivers 25 litres/min at up to 10 bar, well Billy it gives that. It is that simple. What day do unvented cylinders give you on delivery rates?
everyday
Last unvented cylinders I fitted in London gave 150Ltrs/min @6bar. :lol:
Nice to know. All the combi data sheets tell you the delivery. I never see sheets telling me that on an unvented cylinder with a 3 bar pressure reducer on it with x incoming flow.
They reduce the pressure & flow, whereas a plate heat exchanger will not as there is no need for a PRV on the inlet, or any other flow restricting valve either, on,y the smaller restriction of the plate.
Wow! You dont even realise a plate will significantly reduce flow rates.
In fact they dont need a pressure reducer just because they create their own restriction.
Have you ever looked closely at a plate HE ?
Tony
You must stop making things up. A 150kW plate on a Domestic house will create a small restriction.
You are not registered.
He is really getting severely mixed up!
He is talking about a 150 kW boiler in a domestic house now!
Most domestic boilers are 12-42 kW Over 60 kW output they are classed as "commercial".
Tony
