new house and the alarm company want £140 for the engineers code
Sensible Options are ....A replace pcb and reprogram
B contact installer pay to have code changed
Yes was considering new pcb but as I'm in no rush at all and have a fully working alarm system, thought I could try the cold attack option.
I did call the installer but they advised £100 call out and £80/hr of work and a replacement PCB can be gotten online for £65
Is there a tamper alarm after x number of wrong entries?
Hi Sally, no idea but I do have the normal set/rest code that I use daily to arm/disarm so I guess that should turn off the alarm if tamper is set off??
What system do you have?
Have you not tried the normal code reset procedure?
Yes i did the normal engineer reset procedure but I feel the NVM is locked because nothing happens.
Can I default the whole PCB to factory (via the default button/power) if NVM locked and then proceed to re-program?? Could this be a work around?
