I am going to install a new oven (2.2 Kw) a microwave/grill (Unknown because I do not have it yet) and an Induction hob (Unknown because I do not have it yet). I am guessing the other units will be more Kw than oven.
I am planning to run in all cables etc but get an electrician to make final connection and test etc.
I have read as much info I can and am still confused.
I assume I would install a B32 MCB in the CU. My CU has only two spare ports; 1 on the RCD and 1 on the non-RCD. Should I install on the RCD?
Run 10 mm T+E cable.
This is where the confusion really starts as I have read and seen many different ways!!
Can I run the 10 mm to a junction box, then run 3 cables to 3 separate FCU with a 13Amp fuse? Or am I talking total C**p and looking at it too simplistically!!
Thanks in advance for any assistance.
I have checked Part P and BS7671 and I assume that I can do the work but need a qualified person to sign off the work, this would also mean that I do not have to inform the building control at the local council?
