I've been scouring the old posts looking for a situation that is similar but have'nt found one so decided to post this.
I'm about to replace a kitchen and want some advice, the current supply is to a freestanding cooker (combined electic double oven and hob) with a double oven and induction hob.
The hob is 6.8 kw
The double oven is 5.8 - 6.3 kw
Current freestanding unit is fed with 6mm run to a 45 amp mcb in the cu.
From what I can work out the current supply is not sufficent for both units.
The cu is about 25 metres away and the cables are currently run through the loft (not sure where, I've not been able to find them). So am I right in thinking the best solution is to add a cooker mini cu (not sure what they're called) and run 2 new 6 mm cables to feed, is 6mm enough).
Or could I run one new 6mm cable and run the hob from the old cooker supply and run the oven from the new one.
I'd like to get the cable installed myself and then get a sparks to come and connect it all up, to save on cost.
Or is there any other suggestions as to the best way to do this.
Any advice would be gratefully recieved, thanks in advance.
The hob is 6.8 kw
