AEG 6.3KW DOUBLE OVEN
27 Aug 2007
I HAVE RECENTLY PURCHASED THIS OVEN AND WANT TO KNOW IF I CAN USE MY EXISTING 6MM CABLE FOR THIS COOKER?
ACCORDING TO THE SPECS THE COOKER IS 6.3 KW AND HAS A FUSE RATING OF 30 AMPS, MY WIRING TO IT IS 6MM WITH A 45 AMP SWITCH AND A B32 AMP TRIP/FUSE AT THE TRIP FUESE BOX, AM I OKAY OR WILL I NEED TO INSTALL 10 MM CABLING AN A HIGHER FUSE???
ANY REPLY WELCOME THANK YOU FOR READING
