New kitchen question
21 Nov 2019
I have a 1977 house that had a kitchen extension put in in 1979. So there is an archway with part wall of 50cm on the left hand side and 90 on the right hand side. I am putting a 15cm base cabinet against the 50cm wall should I put an end panel on the whole unit or just the 10cm that is showing?
Does that leave a section with the carcass where small items can drop down the side onto the floor , that would be my consideration , and will this save some money - ie can you use the other part of the end panel elsewhere ?
Is this just the base unit or also a wall unit ????
How will the worktop finish - will it go round the front of wall a little - again my change depending on the finished look you want
Any pics , descriptions a bit vague .
the wall is the corner of the new room but its the left hand side of an arch the bit that sticks out is the wall of the arch
I know what a wall looks like , I don’t know what your room looks like , the shape or the dimensions.
its a square room 3.15 metres wide 2.97 meters long with a door in the corner on the long wall that leads to the back porch cloakroom and study
