Do we know that none of the meters with output isolators/switches aren't DP?
I think i have a siemens meter somewhere, i will pull it apart later and check but it is allmost certainly SP
Thanks. It occurs to me, BTW, that the meters with isolators I've seen are not Smart Meters, which may have confused the discussion a bit.I think i have a siemens meter somewhere, i will pull it apart later and check but it is allmost certainly SP
As for the neutral, it is impossible for it to be dead.Work on or near live conductors
14. No person shall be engaged in any work activity on or so near any live conductor (other than one suitably covered with insulating material so as to prevent danger) that danger may arise unless–
(a)it is unreasonable in all the circumstances for it to be dead;
Apparently that covers undoing two screws on the supply end (of neutral) however the live has been disconnected..and .
(b)it is reasonable in all the circumstances for him to be at work on or near it while it is live;
That's reasonable.and .
(c)suitable precautions (including where necessary the provision of suitable protective equipment) are taken to prevent injury. .
How is that meter doing 'metering'? Most of the load current is obviously going along that copper bar (the 'switch') - is it just monitoring the voltage drop across a short length of that bar, via the red/black pair (and monitoring the voltage between the blue and brown), or what?
Not for you it isn't. For you it is possible for it to be dead.As for the neutral, it is impossible for it to be dead.
It covers it for a DNO or metering company employee who is authorised to do it.Apparently that covers undoing two screws on the supply end (of neutral) however the live has been disconnected..
Thanks. A close-up of where that red/black pair meet the copper bar/strip might be interesting. If it is measuring current by voltage drop along that short segment of the bar, considerable precision in the attachment of those leads would be required to get reasonable accuracy!I am not sure of the actual working of the unit but i will take another picture of the reverse of the parts so you may be able to see something there.
Or a non-volatile case-by-case calibration setting in the processor.If it is measuring current by voltage drop along that short segment of the bar, considerable precision in the attachment of those leads would be required to get reasonable accuracy!
Kind Regards, John.
Same here. I was actually expecting to see a current transformer (plus voltage/phase measurement).I thought there would be a pick-up coil, or some kind of solid-state sensor.
Yes, I suppose that would work. It would presumably needs some temperature compensating measures, too.Or a non-volatile case-by-case calibration setting in the processor.If it is measuring current by voltage drop along that short segment of the bar, considerable precision in the attachment of those leads would be required to get reasonable accuracy!
Even if it is a SP switch?On meters with an inbuilt switch, access is available to both the Line and Neutral outgoing terminals.
Right. Thanks again. Do I take it that the thing to which the red/black are connected looks like just a bit of copper or brass, with nothing else 'clever' going on? If so, then I guess that DetlefSchmitz must be right.<piccies>
