Apologies for somewhat late comment - I thought that I had commented before - but it seems that was not the case ...... Clean earthing involves two separate earthing systems. The cable and metallic fittings ( back boxes etc ) are protected by the standard earthing system of a conductor in the cables. The earths in the sockets connect to a separate earth system which is grounded to a clean ( free of electrical noise ) earth. Often a ground rod or rods.
How does this 'clean earthing'work? As far as the installation is concerned, the 'clean earth' ("often a ground rod or rods") would presumably be an extraneous-c-p, and therefore would have to be bonded to the "standard earthing system". Otherwise, using the arrangement shown in the illustration you posted, there would be a risk under fault conditions that a dangerous potential difference could arise between exposed-conductive parts of connected Class I equipment and anything connected to the 'standard earthing system' (including metal faceplate and/or faceplate screws of a socket such as you {MK} illustrated).
If one would have to bond the 'clean' earth to the 'standard' one, the former presumably would become as 'dirty' as the latter?
Kind Regards, John
