Hi, I have got a new outside PIR light and it has three terminals, live, neutral and switched live, wiring from garage is from sockets so has live, neutral and earth, what connects to what?
You run a cable from the socket in to a light switch. That creates the switched live. The cable before the light switch is a permanent live, you can split it to become both live and switched live.
Ideally you will run from a socket up to a switched fused spur, before running up to the new light switch. That will help you to isolate it.
You will need to use 3 core and earth. Even though your PIR might not have a terminal for the earth, the earth needs to be connected to the wall socket just in case, for example, someone accidentally cuts through the cable.
