Oh dear; PVA can be a plasterers best friend but unfortunately it has no place in a tillers world & can a problem, particularly in wet areas. Standard PVA should never be used as a tile primer or in preparation for tiling, the problem is it remains water solvent & can re-activate when subject to water/damp; is this a wet tile area?So, cement based tile adhesive. If I go down this route what is acrylic prime and how do I use it? Will it go over the PVA I've already put on the wall?
Too late now really but give the area a good going over with a stiff wire brush, acrylic prime http://www.bal-adhesives.co.uk/products/prime-apd (or similar) & then fill out with Rapidset tile adhesive a couple of hours before you tile. The area you have is not particularly large so, hopefully, you should be OK but you haven’t said what size weight tiles your using?
Before you move to the tiling stage of your project (preferably even sooner
