- Joined
- 19 Dec 2010
- Messages
- 12
- Reaction score
- 0
- Country
I've just had a new radiator fitted but it does not heat up at all and both pipes are also cold the rst of my radiators are working normally.
When the plumber fitted it he turned off the combi boiler and opened up both pipes from the old radiator, there was a small amount of water from the lockshield side and a lot of water from the TRV side. (should the boiler have been drained as well?)
I've tried the following;
Taken the top off the TRV and checked that the pin is moving up and down about 2-4 mm which it is.
Turned off all the other radiators to try and get the radiator going.
Turned the boiler up to maximum.
Bled all of the radiators in the house.
Nothings worked yet,any suggestions?
