New radiators in extension - builder wants to run pipes up and over
5 Aug 2015
Hi, can any one clarify
We are having an extension modified to provide disabled facilities in our bungalow. The builder wants to run the copper pipes up and across the roof space for two radiators. Will this mean the system will be hard to balance (the rest of the bungalow is fed via pipes in the floor)
( combi boiler serving 6 rads + 2 new Hydronic plinth heaters)
PW
1 Jul 2007
Hertfordshire & London
Balancing won't be a problem as long as the pipes are sized properly.
Is the system sealed?
Decent air elimination will be needed.
Be wary of builder's plumbers. Not all have a clue.
5 Aug 2015
Cheers Shabani
By sealed do you mean closed and pressurised to about 1bar/14psi then yes.
I hadn't considered the air locking possibilities, I was just worried about head difference. wont know about sizing until they strip out the old bathroom because the pipes diverge behind boxed in stuff. I take the point about Builders plumbers
PW
26 Jun 2004
London
Really the pipes should have an auto or manual air bleed point at the highest part of the pipes.
But the auto ones can leak so after they have removed all the air they should be closed off.
The extra length of pipes will make little difference if the system has been correctly balanced. But not all do that.
Tony
