I've done a search for this and have read several posts and where a new ring main is to be installed on the ground floor and the floors are solid concrete, the concensus seems to be to chase the wall vertically upwards from the sockets upto the ceiling and drop the cables from the floor above however, the property is also going to have a full damp course done, which means all of the existing skirtings on the ground floor are going to be taken off and replaced.
Would it be acceptable to chase-out the plaster down from the socket positions to the concrete floor and then run the new cables behind the skirtings. The new plaster will finish about 25mm off the concrete floor so perhaps the cables could be tucked within this gap between floor and plaster and be clipped to either the floor or to the bit of exposed brickwork between the floor and the plaster. This would also ensure that the fixings for the skirtings do not catch the cables. Thanks.
