Hi chaps,
I've got a house with solid concrete floors, on top of which there are standard width wooden planks screwed down into the concrete, on top of which is a carpet.
All the sockets on the ground floor are currently spurs. I'd like to update it and get them all on a downstairs ring main.
One of the ways I've been told is that the cabling needs to come from the top floor to the required height for the sockets and then chase horizontally across to the next one. Then once at the last socket to take it back up again to complete the ring.
Another option I'm considering is one I would like advice on from the pro's. I'm thinking to remove the wooden planks and chase out the concrete, put cable in conduit, backfill with weak mixture of sand cement, then replace floorboards.
Is this a part P acceptable solution or is method 1 the preferred route to take?
Cheers.
Cheers.
