Hi guys about a month ago we had a rockdoor fitted with the 4 hook locking system.
It's a winkhaus lock mechanism...anyway the door rattles when the handle is lifted, and I shut the internal door behind it. If I push the door into the frame when locked it doesn't rattle, but when you press the handle to check the doors locked the door jumps back out of the frame slightly.
I have also noticed when the door hooks are engaged and the door is open the 4 hooks seem to move back 4-5mm when you press the handle down.. Is that normal.
I have checked the door and it seems level, the doors under warranty so will be getting the fitters back, but if I have some idea what they should be doing to fix it, they hopefully won't try to bodge a repair.
I have noticed that all the keeps seem to be set slight differently and and the bottom one is at a odd angle
Cheers
Chris
Cheers
Chris
