New room thermostat
29 Oct 2004
I'm trying to improve our new home's central heating, and have been recommended by a work colleague to get a Programmable Room Thermostat. I don't quite understand all the terminology, so i have a few questions;
Can i just replace my old mechanical thermostat with anything?
What does volt free mean?
Wiring-wise - do i just replace the existing with new?
What do I do with the current timer which turns the CH/HW on/off - does this need to be by-passed, or does it get set to ON all the time?
Steven
err no it depends what you have at the mo (if only it was that easy)
there is no link to mains voltage inside
ie its just a switch the wiring provides the power to switch
not usually
either :wink:
thanks for the quick reply
so in order to proceed, what do I need to check with my current system?
Have a look at the room thermostat - check the wiring - what am I looking for?
When you say 'either' - what do you mean. I only want to replace the thermostat in the room.
I'm assuming that;
The room thermostat is a switch - when temp drops, the switch is 'live' this tells the boiler (via the programmer) to turn on?
If that is the case, there is a wired connection between the room thermostat and the programmer?
How does the room thermostat 'over-ride' the programmer - do I basically leave the programmer set to 'on'
look for how many wires you have
you can leave the existing timer on constant or link it out
yes
yes
yes :wink:
Watch what you buy,
when they 6 on/off it really means 6 times which temps can bet set.
Also you need to make sure the thermostat can be set to a low tempature of say 5 degrees.
therefore with 6 on/offs you can have 3 on's 3 off's with frost protection at 5 degrees.
i just bought this one, and it seems to work well. I did try a cheapy from screwfix. the frost protection was 5 degrees but the lowest temp you could set the stat was 10 degrees, what a joke.... also 5 on offs is rubbish you need the six...
http://www.screwfix.com/prods/76816...Controls/Drayton-Digistat-3RF-Room-Thermostat
the wiring is fairly simple. they seem to all have common, call for heat , call for cooling. You just ignore the call for cooling.
Also live neutral for the receiver.
all fairly easy to do.
thanks for all the replies
I agree, wireless not needed - I don't think...the thermostat is already there and wired in, so might as well use that?
Will have a look at the wiring into the current stat, and take it from there.
It's one of those dodgy Potterton boilers that everyone on the internet says keeps breaking!
Not a combi
As an aside - the whole system needs a bit of an MOT. What else would you suggest is a DIY job?
Clean it?
Add some of that treatment?
Balance the system (some Rads aren't very hot)
anything else?
Update:
got around to viewing the wires in the current thermostat
it just has normal twin and earth - red/black/earth
What kind of replacement will work with that?
thanks
Update:
You said you have a Potterton boiler. Which exact model?
What is the make and model of your existing thermostat?
Wire colours mean nothing - it all depends on how they are connected up.
Boiler is a Suprima L
The current programmer is a Drayton Tempus Seven
I'm not sure what the thermostat is - I think it's a honeywell, it's old
That model needs 240 volt to turn it on. So you can use either a mains of a volt free programmable thermostat, but the wiring is slightly different.
The Drayton Tempus Seven will be retained to provide HW timings.
I need to know what the three wires of the existing stat connect to; then I can tell you how to connect up your new prog stat, though it might be best if you bought that first. The Honeywell CM series are very good, they come in 1 and 7 day versions, in wired and wireless version.
Surely a twin and earth would indicate a live and a switchline?
