New shower installation
6 Jun 2009
Cheshire
Hi Guys,
I will be installing an electric shower next week (Mira Play 9.5kw), was thinking about using plastic pipes and a push fit connector to the shower because the water inlet on the shower is 15mm plastic. Is this a good idea or am I looking at problems further down the line?
most miras will useally use a compression fitting to join to the shower.
if mi state a compression then use a compression.
you can use compression on plastic pipe.
So if I fit a compression joint onto the pipe, I can then just insert my plastic pipe on the other end yeah? Also will I need to use inserts on both pipes or just the plastic pipe which I am fitting? Thanks.
