want to install a 10.5kw elec shower. Have good mains pressure and intend to use 16mm2 wiring. what type of pipe fittings are advised for a diy project. (push fit ?) appreciate any tips
When I fit showers, I often have to do a small modification to the cold water feed. I like to use a soldered joint - it looks better and I believe it to be more secure. Pushfit is obviously more convenient and cheaper!
I'd ask a plumbing forum as cold water feeds to showers is about as far as I go into plumbing!
