I intend to fit a 10.5kw electric shower using 10mm twin & earth, the total distance of wiring is approx. 10 metres including via the 45amp pull switch, is a 40amp fuse rating on the consumer unit adequate
Just before you get your coat, check the poster's location...Adam_151 said:you should aslo know its notifiable under part p of the building regulations...
And what if you can't get one for your board?Hillfold said:Ok thanks again, point taken , I`ll go for a 45amp mcb.
