Replacing a 7kw shower with a 10.5kw.
I think the cable is a 6mm so replacing with a 10mm. The original was the three red, black and green loose in a conduit from the consumer unit to twin pole isolator to shower 8 meter run.
The consumer unit is a Hager which was fitted with a 32A breaker for the shower. I have replaced that with a 50A as was told that a 45A was not available but 50 was OK. There is no RCD in the consumer unit so am thinking about putting one in the circuit on exit from consumer unit.
tlc.direct have such RCD's in their own box for such installations, guessing I will need the 63amp as 40amp to weak.
Summing up, new 50 amp breaker, 63 amp RCD protector in circuit, 10mm wire, (8m run), 45amp twin pole isolator switch.
I am capable of the installation, just want confirmation rating are correct.
Any help appreciated
Dave
Dave
