Noise issue in use, it'll resonate on the shelf. As Dan mentions use something heavy to absorb the vibration
Can a pump run correctly in the loft - yes - all things being correct. Can it have issues, definitely, as it is not in an ideal location and will be susceptible to air locks and/or flow issues and needs to be installed and commissioned very precisely
- You need a LP shower that will allow a suitable pressure drop in the pipework for the pump to activate
- The pump must be at least 1m below the cold water storage cistern (CWSC)
- keep the pipe run at 22mm right till the outlet, keep as short as possible and bends to a minimum
- No pipework above the CWSC and as little pipework as possible above the pump
- Dedicated feeds for both hot and cold, with the hot being via a flange to give an air free supply - If it's a free flow side tapping, an anti grav loop needs to be installed if pump is above the outlet.
