Hi
Just wanted to start planning and get an idea of materials and setting out?
I am looking to do most (if not all the) first fix and have spark connect and test.
The existing wiring is on a RCD (10 yr old CU) and looks to have been split into a radial circuit. The new extension internally would require 8 - 10 double sockets, 8 downlighters and externally 2 weatherproof sockets and maybe 4 x IP65 lights.
Would you suggest we run a new feed (6mm?) off CU with its own sub panel with 32A mcb for sockets and 16A mcb for lights?
Or is it best to simply add new radial to existing CU again with their own mcb's (on 2.5mm & 1.5mm)?
Many thanks for any help/advice?
Cheers!
Cheers!
