New Skirting board: Fit Level or follow the Brick-line?
10 Feb 2022
Hi all,
I’m fitting a new skirting board to my small utility room where all walls are made of brick. Problem is, the brick line is not level. I’ve a unit to the side, which the baseboard hits up against on one side. The baseboard sits lower than the unit bottom edge though. Butting up against the brick work on the wall opposite.
If I match the baseboard to the unit, it creates a nasty looking ‘wedge’ shape in the brickwork at the opposite end. If I raise the baseboard level to even out the wedge, I end up with a huge 12mm gap under the board to the carpet
What should I do or which way would you tackle this?
pics here: https://imgur.com/a/R5GwThX
If I couldn't level the floor before starting, I'd scribe the underside of the skirting to the floor so that the bottom is fairly tight to the floor and the top runs parallel to the brick courses.
To do this you'll need to find the lowest point in the room and work outwards from there, marking the top of the skirting on the wall in pencil at that point. Then transfer the heights at various points to the skirting and trim it down with a saw and a block plane. The gap at the bottom of the unit can be covered with beading, but why is there such a gap? Is the floor out of level across the front of the units as well?
I would use a wider (taller) skirting board, and 'taper' the bottom of the skirting board - so the top edge of the skirting board is in-line with the brickwork.
It would mean the skirting board is going to be taller at one end - but with a wider (taller) skirting board this will be less obvious.
