Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
No idea why it's going to be that particular model. That's the model recommended by the plumber. A second quote we had suggested we get a Atag. (I've never heard of them but happy to go on recommendations).
Boiler is going to be an Ecotec 37kw. Not sure what's in there at the moment but we have rads spread over four floors and 2 kids who in a few years will no doubt be needing showers at the same time etc.
37kW!? Do you live in a castle? 37kW is enough to run about 40 radiators. An oversized boiler will be expensive & inefficient to run, and will have a shorter lifespan. Has your installer done a full room-by-room heat loss calculation to determine the correct size of boiler for your property, as required by Part L of the Building Regulations?
I can but ask the question. You're right though, 38kw is oversized based on our requirements. Knowing almost nothing about boilers I've put trust in the installer to make the right decision.
We have 2 bathrooms and 15 rads.. I'd imagine something around the 28kw would have sufficed. Perhaps it was a typo?
If they turn up with a 37kW I'd politely but firmly tell them to take it away again. All installations carried out after 15th June 2022 MUST be accompanied by a full heat loss calculation demonstrating that the boiler selected is appropriate for the property. This is part of Building Regulations. It is no longer acceptable to fit oversized boilers or use guesswork to determine boiler size. Ask to see their calculations, and if they've not done any direct them to www.heat-engineer.com where they will find a comprehensive heat loss calculator.
Don't allow yourself to be saddled with an oversized boiler which will be inefficient to run and have a shorter lifespan than a correctly sized one. You wouldn't put a Ferrari engine in a Mini, don't do the same to your house
