- Joined
- 31 May 2023
- Messages
- 9
- Reaction score
- 4
- Country
We had an old bath/shower mixer tap which worked well but looked bad, so we replaced with a very similar one, but now the water temperature fluctuates slightly from warmer to cooler about once a second, when using either the bath or shower. We have a combi boiler and it doesn't appear to be cutting out or changing temp when the tap is running. The shower head and bath tap both have eco restrictors but if I remove the shower head the temp still fluctuates. Mixer taps on sinks in the house don't have this problem.
Nothing with the plumbing has been changed except the tap, so I'm wondering, could it be one of the following reasons:
- Flow rate of the new tap (10L/min) is different from the old one and that's causing issues
- The old tap had one handle to adjust the water temp, the new tap has two separate handles
- The new tap is faulty or badly designed in some way?
FYI, this is the new tap: https://www.screwfix.com/p/swirl-ca...ap/190pg#product_additional_details_container
Thanks for any advice!
