NEW WASHING MACHINE CAUSES VERY LOUD BANGING FROM BOILER!?
29 Sep 2009
Devon
Hello,
I have just connected a new washing machine up; it has hot and cold inlet pipes that I have connected to a single water-pipe using a 'Y'-connector.
While the washing machine was running I turned the central heating on- a couple of minutes later the boiler (or possibly the pipes leading into it....?) -started making an extremely load banging noise (much louder then the washing machine that was on full spin!!)...
-i turned off the boiler and ran next door fully expecting the bloody thing to blow up!!
-any ideas as to what caused it?
-is it safe to turn the boiler back on?
-do I just avoid running both at the same time?
(The copper-pipe that the washing machine's hose connects to has another pipe connected to it via a (metal) flexible hose(?). This has a valve that is set to open... -not sure whether I turned it on or off (-is it supposed to be on or not?!?).
The pipes that the washingmachine is connected to, are located a foot or two below the boiler.....
Please note: my understanding of all things plumbing is very limited!! -thanks
does the metal hose look anything like these?
http://www.altecnic.co.uk/Sealed System Components/filling_loops.aspx
if it does switch it off and check the pressure on the boiler
-Yes (middle left one with 2 cut-off valves). when you say 'switch it off' you mean the valves on the hose...? -i've done this, the pressure needle has remained near it's red line...
-while the boiler was going crazy the pressure needle was jumping from about 2 bar to 2.5 bar (its currently on 3 -goes up to 4....)....??
cool, thanks picasso, ... seems to be ok,
-is it ok to use the washingmachine still/ at the same time?
yes its ok to use the w/machine and put your glasses on, the last reply was from kevplumb :wink:
