- Joined
- 21 Dec 2017
- Messages
- 249
- Reaction score
- 48
- Country
I need to run a new service pipe to my house to replace the current 15mm (I think) pipe from the stopcock in the street (12m or so) and move the entry point to a different room.
I'm going to use an 'Insuduct' to bring the pipe through the wall above ground level as it's a concrete floor. I think where the pipe rises up from the trench and goes through the wall will be 25mm MDPE pipe as it looks like you can get their 'hockeystick' which turns 90 degrees only in 25mm size. Besides, I'd only have to step straight down to a smaller size inside the house anyway.
So the question is - is there any benefit to piping from the street stopcock to the insuduct in 32mm and then reducing down at the bottom of the trench to 25mm to go up the insuduct? Or rather, is there any reason that I should NOT do that and just run 25mm all the way from the street?
