Hi
We have just built a new garage about 5 metres from the property and want to connect an electric shower (to wash the dogs). We have had the electrics done (inc a feed for a 7.5kw shower) but need to work out how best to connect off the existing water supply where it comes from the house to the outside tap.
I will dig a trench 750mm down between the two buildings and/or ensure we use an insulated 4"duct but I am somewhat at a loss on how to ensure I don't bury any connections when we need to bring the pipework up at 90 degrees from the ground against the wall to enter the property. The property is on a hill so the damp course is several courses above the current ground level plus the garage is built against higher ground where the water needs to come in so need to ensure the pipe passes into the garage above the damp proof membrane etc
What is my best method of connecting the 20mm mdpe to the feed for the outside tap ensuring I can still have an outside tap and that I comply with refs etc..
Any advice appreciated
Lisa
Lisa
