Can anyone help with this problem?
I have recently replaced a Salamander 2.5 bar, negative head, whole-house, twin impeller pump with a new 3.0 bar Grundfos pump (Amazon STN-3.0B). It was pretty much a like for like replacement apart from a little alteration to pipework to allow for the pump being a little taller, and having to install sperate full bore isolation valves.
Since installing this new pump, I am now experiencing temperature fluctuations (shower gets very hot if someone flushes a toilet) this never happened with the old pump (replaced because it was leaking and generally unreliable). The pressure seems OK but no more powerful than the old 2.5b pump.
The pump is fed directly from the cold storage tank via 28mm reducing to 22mm near the pump, and 22 mm from the 210 ltr cylinder via Essex flange, no other draw on the pipework before the pump. The pump is on the floor next to the cylinder. Temp stat set to 50c. 100 gallon storage tank in loft. One ensuite has negative head. All shower mixers etc are less than 2 years old and only ever used with softened water. The main shower (the one that I have noticed the problem with) is a Grohe. Pipework from pump to each bathroom is 22mm, reducing to 15mm for each tap/toilet etc.
Let me know if I have left anything out!
Thanks in advance for your help.
Grommett
Grommett
