Hi all, this is my 1st post to the forum and would really appreciate it if someone could give me some advice on the wiring for a new hob & double oven.
My current circuit is 40amp MCB at the consumer unit with 10mm2 cable to 45 amp CCU (with socket), then 10mm2 cable to terminal outlet box and our current appliance is a freestanding double oven rated 9.8 to 10.7kw.
I plan to order a new built in double oven and hob with the following max ratings - Oven 5.3kw - Hob 7.2kw and have the following questions:-
1. I plan to replace the 10mm wiring between CCU and Terminal Outlet box with 6mm2 (i'm assuming 6mm cable is sufficient as everything i've read suggests it is?) but am unsure whether to have one outlet box (connecting both oven and hob to the one outlet) or run two separate 6mm cables from CCU to two outlet boxes. What is the best option? (the hob will be directly over the oven and less than 2 metres away from the CCU).
2. Is the current MCB (40amp) ok?
3. Will I have to replace the CCU to one without a socket?
4. The installation book for the oven indicates that if the outlet box is behind the oven the top of it should be no more than 130mm above floor level - is this correct?
Any advice on the above would be great as I want to be in compliance with the regs as will want to get this and the new ring main i've put in certificated once all is done.
Thanks.
Thanks.
