New wiring required for replacement shower?
7 Dec 2005
Fife
Hi
I've got a thread running in the plumbing section about me probably replacing my electric shower. See http://www.diynot.com/forums/viewtopic.php?t=38135 for details. My current shower is an old Mira M7, which is a 7.5kw unit, I believe.
If I end up having to buy a new unit, one of the guys in plumbing mentioned I may not be able to get away with using the current wiring. Can you give any advice on this please? Having had a quick look at the B&Q and Focus websites, the cheaper end of the market units seem to start at 8.5 or 9.5kw and it's probably one of these I'd get.
Cheers
Possibly not.
Probably not?
What is the size of your existing cable?
How long is the cable?
Where does it run on its way from CU to shower?
What is the type and rating of the protective device, i.e. fuse/MCB?
What is the type and main switch rating of the fusebox/consumer unit?
Is the shower circuit RCD protected? (not essential, but a BGI) If so, what is the rating of the RCD?
Advice 1 Do a search on the Electrics UK forum for shower - you'll probably find all you need to know.
Advice 2 Unless you are very confident that you can do it competently and safely, plan on getting an electrician in to do the work. If you do DIY, find out the legal position first. I'm sure thebaldelectrician will point you at the info on his site. I've no beef with him, and no reason to suspect that the info is inaccurate, other than the generic fact that information like that often is, and that you really should look at what the actual law says.
Advice 3 If you are going to have new wiring, take advantage of it by having a 10.5-ish shower.
On the basis that my answer to most of these questions is 'erm...dunno', I guess I'd better get the number of a local spark. :oops:
Cheers
