Solved ... I removed 4 corner clips by inserting thin metal bar into gap at edge of door to contact bottom of each clip. Light tapping pushed clips out. Might not be the correct way ... but it worked. The door then came apart to reveal broken spring.
The springs are slightly different for left and right so be sure to order correct one.
